This recipe shows how to create dynamic columns based on range.
- Create a report template (AgingReport.rml) using the composite datasource (Calculation.ds).
- Define the following parameters into “Report > Parameters” tab page:(Param1) Name=min, Value=${min##30}
(Param2) Name=range, Value=${range##30}
(Param3) Name=snapP, Value=${snapP#choice(Yes,No)#Yes} - Enter the following script:
- On “Report Properties > On Render End” tab:rd = this.getRenderDetails(“application/vnd.ms-excel”);
if (rd==null) // no render details for this mime-type stored
// create a RenderDetails for the right type and add it to the report
rd = new RenderDetails();
rd.setMimeType(“application/vnd.ms-excel”);
this.addRenderDetails(rd);
rd.setParameterValue(“Snap”,Properties.getProperty(“snapP”)); - On “Functions > On Render Begin”:determineRange(Properties.getProperty(“min”),Properties.getProperty(“range”))
- Enter the correct script for each data field, as shown in the “Layout” tab page of the report template (AgingReport.rml).
HowToDynamicColumnWithRange.zip (6.5 KB)
