This guideline will guide you to configure Oracle Connection Pool on Repertoire 202x Designer.
Deploy the Oracle JDBC driver inside \lib or \ext directory under the Repertoire Designer 202x installation folder
Copy the hikari-sample.properties located at \etc directory under Repertoire 202x server installation folder and paste it on \etc directory under Repertoire Designer 202x installation folder. Rename it to oracle.properties.
Edit the oracle.properties file as follows.
dataSourceClassName=oracle.jdbc.pool.OracleDataSource
dataSource.url=jdbc:oracle:thin:@::
dataSource.user=username
dataSource.password=password -
Edit application.conf to point to the oracle connection properties.
elixir.data.jdbc.connection-pool {
definition {
#Add JDBC Properties as below
#mysql = “/home/anyuser/build/hikari-mysql.properties”
derby = “./etc/derby.properties”
oracle = “./etc/oracle.properties”
To encrypt the connection pool password, you can run the bin\repertoire-cli.bat ← located at Repertoire Server 202x installation folder. Below is the command line.
c:\Repertoire 202x\Repertoire 202x\bin>repertoire-cli.bat encrypt
Note : = your password to login into your Oracle database.The command will return the following
password = {enc:elx-2.0}PofjLrwKW2yybzyy5wiZi/RnSdfSuND2jboElU5I3wU= -
Replace the encrypted password inside the oracle.properties
dataSource.password={enc:elx-2.0}PofjLrwKW2yybzyy5wiZi/RnSdfSuND2jboElU5I3wU= -
Start the run-designer.bat and you should see below connection to Oracle is successful
Inside the designer, create a new JDBC datasource and you will see the Oracle listed on the connection pool field
