On Linux Environment:
For Ambience 4.x
- Open a command line console & navigate to /elx-ambience-4.x/bin of your Ambience installation path.
- Execute the command below:
./ambience encrypt <your-secret-key>
On Windows Environment:
For Ambience 4x
- Open a command line console & navigate to /elx-ambience-4.x/bin directory of your Ambience installation path.
ambience.bat encrypt <your-secret-key>
- Output Example, (using mypassword as a plain text password example.)
user@user:/elx-ambience-4x/bin$ ./ambience encrypt mypassword
mypassword = Y0tzTxoSeEbzrKj6Q8VTXA==
Additional Notes
- Encrypting the same input will produce a different output each time.
- To include in spaces in your secret key, do wrap up the entire key with double quotes (" ") which would not be considered part of the key.
- For further details, do view the following post: Encrypting using Ambience/Repertoire 202x - #2 by jpriddey
