The resource bundle file needs to be placed in ${ELIXIR_HOME}/ext/
Locale is defined using the dynamic parameter passed in from the report.
A function is called on Render Begins of the page header to initialise the Resource Bundle.
To test out, the only four set of locale available for this bundle is :-
- French (fr,FR)
- German (de,DE)
- Chinese (zh,CN)
- Japanese (ja,JP)
Sample on Resource Bundle is available at the following link: Using Resource Bundle
To use the sample :
- Download ‘ResourceBundle.zip’ from the above link
- Unzip ‘ResourceBundle.zip’ to a folder
- Copy ‘Labels.jar’ and place at ${ELIXIR_HOME}\ext
- Run Elixir Report Professional
- Click on ‘Add FileSystem’ and select ‘Jar FileSystem’
- Enter ‘KnowledgeBase’ for Name and locate ‘ResourceBundle.jar’ at the folder that ‘ResourceBundle.zip’ is unzipped to
