Disabling Ciphers at the JVM Level
SSL configurations are carried out at the JVM level for Ambience/Repertoire 202x.
  1. Edit /conf/security/java.security file of the Java installation to prevent the Elixir Ambience/Repertoire Server from using weak ciphers.
  2. Search for ‘jdk.tls.disabledAlgorithms=’ in /conf/security/java.security
  3. Revise 'jdk.tls.disabledAlgorithms= ’ to include the required ciphers, e.g.
    jdk.tls.disabledAlgorithms=SSLv3, TLSv1, TLSv1.1, DTLSv1.0, RC4, DES, 3DES_EDE_CBC,  CBC, TLS_RSA_*, CCM, CCM_8, MD5withRSA, SHA1, DH keySize < 2048, EC keySize < 224, anon, NULL, ECDH
  4. Run ‘java -XshowSettings:security -version 2>&1’ at the command line to verify the list of disabled algorithms printed towards the end of the stack.
