Copying API Tokens Between Two Repertoire 202x Instances
There are two supported approaches to replicate API tokens across multiple Repertoire Server 202x installations:
Method 1: Full Installation Duplication
  1. Create an API Token on the source server.
  2. Stop the server.
  3. Duplicate the entire Repertoire installation folder to a new location/server.
  4. Start both servers.
Both instances will then share the same API tokens for the corresponding users.
Method 2: Data Folder Migration
  2. Copy the /data folder from the source installation.
  3. Replace the /data folder of the target Repertoire installation with the copied version.
  4. Start the target server.
The API tokens from the source instance will now be available on the target.
