Ambience 2020+ requires MongoDB for the storing of its system data. The example below illustrates how to automate the rotation of the MongoDB logs in a Unix environment using the system’s logrotate utility.
Create a ‘mongodb’ file in the /logrotate.d directory, e.g. :
vi /etc/logrotate.d/mongodb -
Insert the following in the mongodb file, replace ‘/var/log/mongodb/mongodb.log’ with your own MongoDB logging path and log file, e.g.
/var/log/mongodb/mongodb.log {
daily
compress
missingok
sharedscripts
postrotate
kill -SIGUSR1 $(cat /var/lib/mongodb/mongod.lock)
endscript
- From the above configuration:
- The MongoDB logs are rotated daily.
- The previous logs are archived using the compress option.
- The missingok option ensures the log rotation script is not disrupted if the mongodb.log file is not found in the log directory.
- The sharedscripts option tells the logrotate utility to run the script under postrotate once, endscript indicates the end of the script.
- The ‘kill -SIGUSR1 $(cat /var/lib/mongodb/mongod.lock)’ command rotates the MongoDB log.
- The rotated MongoDB logs will have a date and timestamp appended to the file name, e.g. mongod.log.2021-08-11T08-06-29
