This entry explains how to configure the idle timeout value for HTTP connections in Ambience 4. The configuration is managed in the jetty-http.xml file located under the /jetty/etc/ folder of your Ambience 4 installation directory. Updating this value ensures that connections are closed after the defined idle period.
Step 1: Locate the Configuration File
Navigate to the following directory in your Ambience 4 installation:
/jetty/etc/
Locate the relevant configuration file:
jetty-http.xml
Step 2: Identify the Idle Timeout Property
Within the file, locate the following configuration block:
<Set name="idleTimeout">
<Property name="jetty.http.idleTimeout" deprecated="http.timeout" default="30000"/>
</Set>
Step 3: Update the Idle Timeout Value
Modify the default value 30000) to your desired timeout in milliseconds. For example, to set the timeout to 60 seconds:
<Property name="jetty.http.idleTimeout" deprecated="http.timeout" default="60000"/>
</Set>
Step 4: Save and Restart
- Save the changes to
jetty-http.xml. - Restart the Ambience service to apply the updatedconfiguration.
