Configuring and Managing Archived Results in Report Portal in Ambience/Repertoire 202x
The Archived Results tab in Report Portal provides access to saved report outputs older than the configured archive period. By default, the archive period is 60 days. Results generated within the preceding 60 days appear under Render Results.
Archived results are organized by their generation year, month, and day.
Prerequisites
Before configuring or using Archived Results, ensure that:
  • User account has the mod-report-portal privilege to access Report Portal.
  • Saved report results are available to user account.
  • User account has mod-report-portal-share if need to share results.
  • An administrator can update etc/application.conf and restart Repertoire Server when changing the archive period.
Step 1: Configure the Archive Period
The default archive period is 60 days. To use a different period, locate etc/application.conf under the Repertoire 202x server installation directory.
Example location:
C:/Elixir/Repertoire-202x/etc/application.conf
Add the following configuration:
ambience.report-portal.archive-results-days = 30
This overrides the 60-day default with a 30-day archive period.
Configuration Render Results Archived Results
Default: 60 days Results from the preceding 60 days Results older than 60 days
Custom: 30 days Results from the preceding 30 days Results older than 30 days
The period is calculated from the result’s generation timestamp using 24-hour days.
For example, with the value set to 30:
A result generated 10 days ago → Render Results
A result generated 45 days ago → Archived Results
Save application.conf, restart Repertoire 202x server for the changes to take effect.
Step 2: Access Archived Results
Navigate to the Report Portal module. Select Archived Results in the left navigation panel.
If the navigation panel is collapsed, expand it to access the Report Portal options.
Step 3: Locate the Required Report
Browse the archive folders in the following order:
Year
  └─ Month
      └─ Day
          └─ Report result
For example, a report generated on 15 August 2026 can be located under:
2026
  └─ 08
      └─ 15
          └─ SalesSummary.pdf
Select the required year, followed by the month and day, to locate the report. Use the parent-folder entry (..) to return to the previous level.
Note: The folders represent the report’s generation date. This may differ from the reporting period inside the document. For example, a July sales report generated in August is located using its August generation date.
Step 4: Search or Refresh the Results
Navigate to the required date folder. Enter part of the report name in the search field.
The search is case-insensitive. For example:
sales
can help locate entries such as:
SalesSummary.pdf
RegionalSales.xlsx
The search filters the entries displayed in the current folder. Browse to the appropriate date folder before searching for a report name.
Clear the search field to display all entries in that folder. Click Refresh to reload the available results.
Step 5: View or Download an Archived Result
Select the required report in the panel. You may view the generated report directly in Report Portal.
Save or download the report if a local copy is required.
Step 6: Rename an Archived Result
Select the checkbox beside one report result. Click More Actions, then select Rename.
In the Rename Report dialog:
  1. Enter a descriptive report name.
  2. Confirm the change.
  3. Verify that the updated name appears in the list.
Note: Report names must be changed individually. Multiple reports cannot be renamed simultaneously.
Step 7: Share an Archived Result
Select the checkbox beside one report result. Click More Actions, then select Share.
In the Share Result dialog:
  1. Click Add.
  2. Select the required user or role in the Users and Roles dialog.
  3. Click OK to add the selection.
  4. Repeat as required for additional recipients.
  5. Review the access list.
  6. Click OK to save the sharing settings.
Recipients can access results shared with them through Shared with Me.
To update existing sharing settings, select the report and reopen Share. Add recipients or remove entries as required, then save the changes.
The Share action requires exactly one report file to be selected and the mod-report-portal-share privilege. The available recipients also depend on the application’s sharing configuration.
Step 8: Delete Unwanted Archived Results
Select the checkbox beside the report result to remove. Click More Actions, then select Delete.
To remove multiple results, select the required report checkboxes before choosing Delete. Review any confirmation prompt carefully.
Refresh the list if necessary to verify that the selected results have been removed.
Note: Delete removes saved report outputs. Download any copies you need before proceeding. Selecting a date folder for deletion can include the results within that folder, so review the selection carefully.
Troubleshooting
i) A report appears in Render Results instead of Archived Results
Check the report’s generation timestamp against the configured archive period.
By default, results remain under Render Results for 60 days. If archive-results-days is set to 30, results remain there until they are older than 30 days.
The reporting period inside the document does not determine its archive classification.
ii) A configuration change has no visible effect
Confirm that the configuration file belongs to the server providing Report Portal.
Verify the setting’s value, restart that server, then refresh the portal. Check for other definitions of the same setting if the effective value remains unexpected.
iii) The expected archived result cannot be found
Browse using the report’s generation date. Clear the search field and refresh the list.
Confirm that you are signed in with the account that owns the result or has been granted access. Check whether the output was deleted or removed by a configured cleanup process.
iv) Searching does not return the expected report
The search filters entries in the current folder.
Navigate to the relevant year, month, and day before searching. Try a shorter search term or clear the field to inspect the complete folder contents.
v) Rename or Share is unavailable
Confirm that exactly one report file is selected. Selecting multiple files or a date folder changes the available actions.
For Share, verify that your account has mod-report-portal-share.
vi) A recipient cannot access a shared result
Reopen the report’s Share dialog and confirm that the intended user or role is listed.
Ask the recipient to refresh Shared with Me. If access was granted through a role, verify the recipient’s role membership.
What This Guide Achieves
  • Explains the default archive period and how to customize it.
  • Helps users locate saved reports by generation date.
  • Provides instructions for renaming, sharing, and deleting results.
  • Identifies common configuration and access issues.
