[Components] RTF
This recipe demonstrates how to reference a RTF file via URL in the report template.
  1. Prepare a RTF file for reference use.
  2. Create a report template (Test.rml):
  3. Add a “RTF” element into the “Section Header”.
  4. On the “RTF Properties > Control Source Type” dropdown list, select “URL”.
  5. In the “URL” text field, enter the URL that links to the RTF file.
RTF.zip (3.7 KB)
