This recipe demonstrates how to change the position of background image, how to change label position, how to change legend font and more.
- Create a blank report template (HowToAddBackGroundImg.rml) and add a variety of charts. Use the correct script to change the position of background image.
- Create a blank report template (HowToChangeLabelPositionInCategory.rml) and add a variety of charts. Change the label position in category accordingly.
- Create a blank report template (HowToChangeLegendFont.rml) and add a variety of charts. Use the correct script to change the legend font and icon.
- Create a blank report template (HowToChangeLegendFontColor.rml) and add a variety of charts. Use the correct script to change the legend font color.
- Create a blank report template (HowToChangeTextOrientation.rml) and add a variety of charts. Use the correct script to change the text orientation for charts.
- Create a blank report template (HowToPlaceYaxisOnRight.rml) and add a variety of charts. Use the correct script to place the Y-axis on the right.
- Create a blank report template (HowToRemoveGridLines.rml) and add a variety of charts. Use the correct script to turn off grid lines.
- Create a blank report template (HowToRemoveOutlineGrayBorder.rml) and add a variety of charts. Use the correct script to remove outline border for charts.
- Create a blank report template (HowToRotateYaxis.rml) and add a variety of charts. Use the correct script to rotate the Y-axis 90 degrees.
- Create a blank report template (HowToShowColorBaseOnValue.rml) and add a variety of charts. Use the correct script to show colors of chart based on the values of the field.
- Create a blank report template (HowToShowCustomColor.rml) and add a variety of charts. Use the correct script to display custom colors for charts.
- Create a blank report template (HowToShowPattern.rml) and add a variety of charts. Use the correct script to display patterns instead of color for charts.
- Create a blank report template (HowToUseColorBasedonRGBorElixirPackage.rml) and a Meter Full Circle Chart. Use the correct script to use the colors based on RGB or Elixir Packages.
General.zip (34.0 KB)
