This recipe demonstrates how to add each type of chart into the report template.
- Create a Blank Report Template.
- Add the following into the “Area Chart” section of the report template:
- Area Chart
- Area Stacked Chart
- Area Stacked Percentage Chart
- Add the following into the “Bar Chart” section:
- Bar Chart
- Bar 3D Chart
- Bar Stacked Chart
- Bar Stacked Percentage Chart
- Add the following into the “Column Chart” section:
- Column Chart
- Column 3D Chart
- Column Stacked Chart
- Column Stacked Percentage Chart
- Add the following into the “Line Chart” section:
- Line Chart
- Wind Chart
- Add the following into the “Meter Chart” section:
- Meter Full Circle Chart
- Meter Half Chord Chart
- Meter Pie Ending Chart
- Thermometer Chart
- Add the following into the “Pie Chart” section:
- Pie Chart
- Pie 3D Chart
- Multiple Pie Chart
- Multiple Pie Chart 3D
- Multiple Ring Chart
- Ring Chart
- Add the following into the “Polar Chart” section:
- Polar Chart
- Add the following into the “Sticks Chart” section:
- Candle Sticks Chart
- High Low Chart
ChartReference.zip (15.2 KB)
