Level: Beginner
Prerequisites: -
Steps Used:
- Array Slice
- Array Slice (Field)
Scenario:
How to modify a field to only retrieve a subset of the value from the initial array field values
ETL Array Slice:
Create a Sample JSON data which includes an Array Field locally & save it as a .json file
For example, sample Data Used: [sampledata3.json]
[{"color": "red","value": "#f00","shades": ["cherry", "rose", "mahogany", "crimson"]}] -
Create a new ETL Chainset.
For example, -
Add a new Blank Chain.
For example,
Add the Step, “URL Reader” & input in your .json file path over in the “URL” field.
For example,
Expand the icon on the top right corner for more details on this step.
Notes:
- Do ensure that the path given in the “URL” field is declared as readable in your Ambience Server “application.conf” file.
- This setting can be found under “elixir.data.url”
Add the Step, “JSON Reader”
Add the step, “Array Slice” & configure the necessary fields
For example,
Expand the icon on the top right corner for more details on this step. -
Run the ETL Steps
Output:
// Initial Data
// After running the chain
[As configured in the Array Slice ETL step, Array index 0 & 1 are rendered in a new column called “result”]
ETL Array Slice (Field)
Sample Data Used:
[{"from": "0", "to": "2", "color": "red", "value": "#f00", "shades": ["cherry", "rose", "mahogany", "crimson"]}]
After importing the data, head over to the ETL module.
More information on how to Import a data can be found here: -
For example,
For example,
Add the step, “MongoDB Definition” & “MongoDB Reader” to view the records.
For example,
[Configure the necessary fields] -
Add the step, “Array Slice(Field)” & configure the necessary fields
For example,
[Expand the icon on the top right corner for more details on this step.] -
Run the ETL Steps
Output:
// Initial Data
[As configured in the Array Slice(Field) ETL step, Array index 0 & 1 are rendered in a new column called “result2” which are based on the column “from” & “to”]
Notes:
- Array Slice example uses a JSON data structure.
- Array Slice (Field) example uses a MongoDB database:collection
