In some cases, multiple Java processes may remain active even after attempting to stop the Ambience 4.x service manually. To avoid repeatedly manually killing processes in Task Manager, you can use a custom Windows batch script to automate the stop–restart cycle of the Ambience service. This ensures all processes are terminated cleanly before restarting.
Steps
- Example to create a new batch file in Windows
Open Notepad and paste the following script:
:: 1. Set date and path for stop-restart logging
SET dt_fmt=%DATE:/=%
SET logpath="C:\ElixirAmbience\log\amb_restart-%dt_fmt%_%time:~0,2%%time:~3,2%%time:~6,2%.log"
:: 2. Log current Ambience Windows Service and Java processes
tasklist /v /fi "Imagename eq Java.exe" >%logpath%
tasklist /v /fi "Imagename eq elx-ambience-service.exe" >>%logpath%
:: 3. Stop Ambience Windows Service and wait 90 seconds
net stop "ElixirAmbience" >>%logpath%
echo Waiting Start Time: %time% >>%logpath%
echo 90sec interval >>%logpath%
TIMEOUT /T 90 /NOBREAK
echo Waiting End Time: %time% >>%logpath%
:: 4. Force kill remaining processes, remove lock file, and wait 90 seconds
taskkill /F /IM elx-ambience-service.exe /T >>%logpath%
taskkill /F /IM Java.exe /T >>%logpath%
del "C:\ElixirAmbience\data\running.lock" >>%logpath%
:: 5. Restart Ambience service
net start "ElixirAmbience" >>%logpath%
echo Ending Date/Time: %DATE%,%time% >>%logpath%
:: 6. Log status after restart
tasklist /v /fi "Imagename eq Java.exe" >>%logpath%
- Save the file
Save the script with a.batextension, for example:
restart-ambience.bat
- Run the script as Administrator
Right-click the batch file and select Run as administrator.
This will:
- Stop the Ambience Windows service.
- Wait 90 seconds to allow Java processes to exit gracefully.
- Force kill any remaining Java processes.
- Remove the
running.lockfile. - Restart the Ambience service.
- Log all actions to the log directory.
- Review the logs
After execution, check the log file under:
The log will include:
- Ambience service status.
- Java processes and their memory usage.
- Timestamps for each action.
Notes
- You can adjust the timeout values (
90 seconds) depending on how long your system takes to release Java processes. - Update the paths (
C:\ElixirAmbience) if your installation is in a different directory. - This script should be run only when Ambience needs to be restarted or when lingering Java processes are observed.
- Use the above script as reference in adapting to Linux systems.
