Authenticated Users
This is an example of how to design a simple ETL chain set for the step, "“Authenticated Users” using the ETL Designer module on Ambience.
Background Information on Authenticated Users:
  • Fetches user authentication logs from the SSO system and emits a record for each login attempt.
  • Information that will be loaded includes, “username”, “timestamp”, “success” & “error”.
  • This information’s are available in the Audit Log.
  • This is useful for use in reports without having to expose the Audit Log to the ETL chains.
Prerequisites:
  • Only works for administrators with mod-identity privilege.
    Privileges can be added either in the Users/Roles module.
Authenticated Users
  1. Navigate to the ETL module & create a new ETL chainset.
  2. In the chainset, add a new chain.
    For example, “Authenticated Users”
  3. Add the step, “JSON Record” & add the following line of code as part of the JSON record.
    For example,
    |405x299.62744539944924
    [Click the icon at the top right corner of the step for more details.]
  4. Next, add the step, “Authenticated Users” & input in the fields as necessary.
    "From Field" is a compulsory field while “To Field” is an optional field.
    For example,
    (i.e. as declared in the step “JSON Record”, the column name used is “from”.
    To declare a “To Field” do add in another record in the previous ETL Step, “JSON Record”.)
    [Click the icon at the top right corner of the step for more details]
  5. Save & run the ETL Steps.
Output:
