Please refer to the attached file for your references.
In our sample:
- import java.io.ByteArrayOutputStream;
- comment out FileOutputStream portion:
//FileOutputStream fos = new FileOutputStream(
//new File("test.pdf"));
- create a ByteArrayOutputStream to store the output, after that you can stream the bytes[] to the users
ByteArrayOutputStream bos = new ByteArrayOutputStream();
byte[] bytes = bos.toByteArray();
APIDemo.txt (6.7 KB)
