Release Notes - Ambience - Version 2023.0
Features and Enhancement
General
- [#NA] - Remove all akka dependency
- [Build#48] - Reject uploading of virus files in the Anti Virus environment
Repository
- [Repository#17] - Repository Enhancements - Preview checkbox
ETL
- [ETL#26] - Category for Scheduler to get status and control triggers
Git Deploy Module
- [Git Deploy#01] - Git Deploy Module
DataSets
- [DataSets#22] - Dataset Datasource
- [DataSets#18] - Cached Dataset
Forms
- [Form#69] - Form Unload Prompt
- [Form#68] - Additional Form Access Control via elxAccess field
RML Engine
- [RML#33] - Write timed out rml rendering activity to Activity Log
User Settings
- [User Settings#9] - Reload of user session after forced password change
Ownership
- [Ownership#12] - Add API module into Ownership
- [Ownership#09] - Batch Set Roles
Bug Fixes
DataSets
- [DataSets#19] - Infer Schema error with ETL chainset using chain name start with #
Record Editors
- [Record Editor#113] - IsoLocalTime - Format - When the hour starts with leading zero, and user saves, the value is displayed as ‘’
- [Record Editor#112] - Hidden field value lost after user edits and saves records
- [Record Editor#111] - Format - When user edits an existing record, the format of the data type is incorrect
- [Record Editor#108] - Add All - The field is added again after user changes name and clicks ‘Add All’
- [Record Editor#107] - Filter with Decimal - The filter does not work when the Decimal number contains Decimal point
- [Record Editor#109] - Filter with IsoLocalTime - The Time picker does not display input field
- [Record Editor#104] - Record Editors - Date Remained Unchanged in Add/Edit Birthdate Field under Set Date Constraints Screen
- [Record Editor#103] - Browser response leaks data when field is not included in the record editor
Redirect
- [Redirect#8] - Redirect with Prefix
- [Redirect#15] - Edit a redirect created by another user returned successful message
- [Redirect#17] - Upload an redirect with overwrite failed
- [Redirect#18] - Decode failure during uploading an redirect
Adhoc Report
- [Adhoc Report#86] - Layout - Align Left - When there is no field in Groups, the column’s header is not displayed
- [Adhoc Report#85] - Layout - Align Left - There are extra rows in the exported file
- [Adhoc Report#84] - Layout - Drill-Down - The width of column’s header in the exported file is smaller than in the rendered report
- [Adhoc Report#83] - Layout - Align Left - The fields are not aligned correctly and footer displays the field’s headers
- [Adhoc Report#87] - Date Format Issues for IsoLocalDate, Timestamps and Numeric
Forms
- [Form#65] - To hide form header when button been clicked using header=false parameter in URL
- [Form#74] - mod-form-runtime checks mod-form-designer privilege
ETL
- [ETL#123] - PDF Render Page to Image step unable to save field
- [ETL#113] - HTTP Bytes Endpoint not displaying record at 2690253 bytes
Dashboards
- [Dashboards#125] - Download View unable to download files with category name containing scripts
- [Dashboards#127] - Dashboard Linear Table Pagination Issue
Upload and Download Management
- [Upload-download#18] - Upload module shows Edit and Delete button for non owner
