Ambience V2022.0 Release
Features and Enhancement
General
  • [Build#42] - Datasets now support mapped database name
Dashboards
  • [Dashboard#120] - Maximise action button on dual axis chart views
ETL
  • [ETL#112] - Workflow ETL: Add/Merge to elxPublic/elxPrivate
  • [ETL#109] - ETL Reset Read-Only feature
  • [ETL#110] - Ambience ETL Text Output
Identity
  • [Identity#07] - Customise Add Account and Reset Account emails
Developer
  • [Developer#17] - Infer Schema in Collections Tab
Forms
  • [Form#41] - Form Date Ranges
  • [Form#42] - Form Button Colours
Record Editors
  • [Record Editor#69] - Hidden Columns
  • [Record Editor#72] - New Filter mechanism for multiple filters on same field
Users
  • [Users#08] - Automatic Adding of Users
Theme
  • [Themes#na] - Theme can now be applied in login page
CMS[Content Management] (Early Access)
  • [CMS#12] - Dropdown Menu & Updates to Styling & Theming Support
API (Early Access)
Bug Fixes
General
  • [Build#43] - Remove Duplicated privilege names in Server
Record Editors
  • [Record Editor#71] - To show error message when user empty input in number field during edit
  • [Record Editor#68] - Add Record issue with “Post Edit Script” and “Pre Edit Script”
Dashboards
  • [Dashboard#118] - Dashboard HTML View changes - download icon renderComplete
  • [Dashboard#119] - Simple Grid and filter not working with numbers
Adhoc Report (Early Access)
  • [Adhoc Report#33] - Filter does not work with datatype = IsoLocalTime
  • [Adhoc Report#28] - Count Operation is not displayed when the results have more than 500 records
  • [Adhoc Report#05] - Group with no Field shows empty rows
  • [Adhoc Report#22] - If user sorts 2 fields, the Sorting function does not work on the second field
  • [Adhoc Report#35] - IsoLocalDate - Format = DD d MM yy - The data table displays ‘IndexOutOfBoundsException’
  • [Adhoc Report#36] - Timestamp - Format = hh:mm - The time should be displayed in 24 hours format
  • [Adhoc Report#44] - Adhoc Report not in Recent files
  • [Adhoc Report#43] - Filter - Timestamp filter shows incorrect results
  • [Adhoc Report#40] - The format of data at the title does not match with the format of data in the data table
  • [Adhoc Report#42] - [DocumentDb]Function - Median - Median does not display for Double / Int64
  • [CMS#05] - The checkbox for Public is unchecked when its opened in edit mode
  • [CMS#08] - Copying from an existing template with different name return the copied template name with new version
  • [CMS#06] - Start Page still shows a deleted page in Group listing
  • [CMS#03] - URL Prefix accepts special characters in Edit mode
  • [CMS#09] - Disallow add template with blank name
  • [CMS#07] - Copying from a parent group does not inherit its start page
  • [CMS#11] - Uninformative error message importing file with invalid filetype
RML & DS
  • [RML#] - Fix for missing negative in XLSX
  • [RML#] - Reworked SVG to Image to handle resizing
  • [DS#] - CompositeScope fix (Derivative lookup script)
