Ambience V2021.3 Release
Features and Enhancement
General
  • [Build#38] - Fix for vulnerable to Cross-Site Scripting in autocomplete
  • [Build#39] - Enhancements on Unknown User page
Dashboards
  • [Dashboard#114] - Dashboard HeatMap Sorting
  • [Dashboard#117] - New dashboard scripting option for tables
ETL
  • [ETL#105] - JWT Encoder / Decoder
  • [ETL#107] - User Management Steps
  • [ETL#106] - ETL Function Mechanism (Function Signature and Function Call)
Workflow
  • [Workflow#8] - Workflow Audit
Licence Deployer
  • [Licence Deployer#2] - New Licence Deployer
Adhoc Report
  • [Adhoc Report#11] - AdhocReport “SortField”
Forms
  • [Form#38] - Date Input component
  • [Form#39] - Year Input component
Record Editors
  • [Record Editor#43] - Allow displaying Actions on the left of the rows
  • [Record Editor#48] - To sync the fields when field types are changed in dataset
  • [Record Editor#42] - Record Editor local storage for filter mechanisms
  • [Record Editor#49] - Pre Display Script - called for each row when shown
  • [Record Editor#53] - Record Editor scripting - Layout
  • [Record Editor#50] - Logging “Added” fields
  • [Record Editor#55] - Extra Fields for reference fields in a record without been visible
Users
  • [Users#7] - Role Disabling
CMS Module (Early Access)
Bug Fixes
General
  • [Build#40] - Failed to decrypt {enc:elx-2.0} password used as keystore password
Developer
  • [Developer#16] - Fix for unable to query ambience->Ambience collection data
Upload-Download
  • [Upload-Download#14] - To keep entered category name unchanged when scripts are used
Record Editors
  • [Record Editor#45] - Fix for Dropdown shows blank list when pre-selected option is not in the Custom Choices
  • [Record Editor#46] - Fix for Local storage for filter cleared and drop-downs display unexpected value after refreshing page
  • [Record Editor#52] - Fix for Properties sub-tab UI issues
  • [Record Editor#61] - Fix for Filters not shown properly on smaller screen
  • [Record Editor#59] - Fix for New record insert _id as UUID instead of bson Object
  • [Record Editor#54] - Fix for User is unable to scroll down in the Add Record dialog when there are many fields to display
  • [Record Editor#66] - Fix to disable Allow new value checkbox when depend on is used
  • [Record Editor#63] - Fix for Pre and Post Edit Scripts: Scripting of individual editable cells - The changes are not saved
Dashboards
  • [Dashboard#116] - Fix for Pivot issue when values don’t exist
Adhoc Report
  • [Adhoc Report#12] - Fix for Adhoc Report icon missing from management page
ETL
  • [ETL#108] - Fix for WebStore Field Writer writing duplicated bytes into store
Forms
  • [Form#40] - Fix for rules failed to work when Id contains dot
GIS Explorer
  • [GIS#71] - Fix for User is able to access GIS designer using URL without need to having same role
Workflow
  • [Workflow#9] - Fix for User is able to access workflow designer using URL without need to having same role
