Features and Enhancement
General
- [Build#32] - Year and Month dropdown in the date/datetime pickers
- [Build#35] - Session cleaner setting
- [Build#36] - Enhanced Logging for mongoldb connection string and read encrypted string from file
Dashboards
- [Dashboard#106] - Select Filter: All or None
- [Dashboard#107] - Linear Table - Support Select to Control
- [Dashboard#109] - Linear Table - Hide Columns in View
- [Dashboard#111] - Dashboard mementos are now remembered across sessions
- [Dashboard#112] - Linear Table - Multi-Select Checkbox and Linear Table Filter
ETL
- [ETL#98] - Authenticated Users step
- [ETL#99] - MongoDB Deep Clone
- [ETL#100] - Aggregation Match step
- [ETL#101] - Inspect string and coloured record
- [ETL#102] - Allows only one edit tab when multiple tabs of the same ETL is opened
- [ETL#103] - Array Chain Each Item step
- [ETL#104] - Composite DS support to read from Dataset
Upload - Download
- [Upload-download#13] - Add ‘Open’ for file types which is supported to view on browsers and add space for ‘ContentType’ column
Datasets
- [Datasets#17] - Dataset Export Pipeline
DeepLearning
- [deep learning#4] - Allow user to update Deep Learning models
Forms
- [Form#35] - Attachment Count / Derived Text
- [Form#36] - Advanced Form+Dashboard integration - Mechanism to pass filter information from forms into a dashboard
Record Editors
- [Record Editor#38] - Export to CSV and XLSX option
- [Record Editor#39] - Allow Multiple boolean records editing
Identity
- [Identity#5] - Disallow common password based on regular expressions
Config Editor
- [Config Editor#1] - Config Editor module
RML Engine
- [RML Engine#31] - Mongodb Datasource support
Adhoc Reports (Early Access)
Bug Fixes
GIS Explorers
- [GIS#70] - Fix for Incorrect wizard tooltip behaviour
Theme
- [Theme#18] - File is not overwritten if the path does not start with ‘/’
Record Editors
- [Record Editor#36] - Fix for not showing value ‘_id’ field value when type is ‘String’
- [Record Editor#37] - Fix for Record Editor Edit Properties Panel cut off
Dashboards
- [Dashboard#108] - Show Totals at the end of columns in Pivot Table gives empty cell in front when export the pivot table
Forms
- [Form#37] - The ‘Workflow’ dropdown and ‘Cancel’ button run out of the ‘Run Form’ dialog when there is a workflow with long name
