Features and Enhancement
General
- [Build#29] - Datasource Timeout Setting
- [Build#30] - New encryption implementation
ETL
- [ETL#93] - New ETL Cleaning steps
- [ETL#94] - Binary Store steps
- [ETL#95] - MongoDB Date Accumulator steps
Import - Export
- [Import-Export#42] - Support import password protected xlsx files
GIS Explorers
- [GIS-Explorer#69] - New GIS Wizard
Ownership
- [Ownership#8] - Added Form and Workflow in Ownership module
Visualisations
- [Viz#52] - Bubble-Scatter chart - Add radius of bubble
- [Viz#53] - Add Hover Template for charts
- [Viz#56] - Timestamp filter
RML Engine
- [RML#30] - Explicit API endpoint for RML engine
DOCX Engine
- [DOCX#6] - Hide table rows in docx using renderBlockIf
- [DOCX#8] - Customised font-folders for Aspose rendered PDF
Kanban
- [Kanban#6] - Kanban Enhancement and Workflow History
Forms
- [Form#18] - Support Tab Bar / Tab Panel
- [Form#20] - Attachments Component
- [Form#22] - Image Component
- [Form#25] - Rule options
- [Form#27] - Linked Form
- [Form#29] - More dynamic select choices
- [Form#30] - Form Redirect URLs - a new ETL Step
- [Form#31] - Small enhancements on Delete Image and Dynamic Values for Checkbox
- [Form#32] - Select component with “Submit on Change” / Sort Field and Sort Ascending in Form Launcher
- [Form#33] - Cascade Groups
- [Form#34] - Parameter ${mode} with hidden field in Form
Record Editors
- [Record Editor#22] - String Choices
- [Record Editor#23] - Custom Record Editor filters
Identity
- [Identity#4] - End-user password reset
Workflows
- [Workflow#7] - Standardise the key and name mapping for databases
Bug Fixes
GIS Explorers
- [GIS#66] - Fix for duplicate density layers when toggling on/off the proximity
- [GIS#67] - Fix for Layer is hidden from the layer control panel
Import and Export
- [Import-Export#43] - Fix for unable to export data with rows exceeding xlsx limit
Layouts
- [Layouts#9] - Fix pop-up text on icon in Layout Designer
Forms
- [Form#17] - Fix for the ‘Disable’ action is applied to all tab panels
- [Form#19] - Fix Dataset checkboxes do not save selections into elxPublic
- [Form#28] - Fix for Number input is not remembered in Details form
Dashboards
- [Dashboard#97] - Fixed upload large files warning message displayed empty in Firefox browser
- [Dashboard#101] - Fix for Linear Table search with missing value
