PDF Guide:
Ambience_Repetoire202x Upgrade Guide.pdf (129.2 KB)
If you are using Repertoire, please refer to the migration guide below, as it provides more detailed information and supporting references:
Migrating from Repertoire 202x to latest 202x build - Repertoire 2022+ - Elixir Support Forum
Prerequisite
Ensure you have the license key for Ambience/Repertoire 202x.
Do not remove/overwrite your current Ambience/Repertoire installation directory
Steps to Upgrade to the Latest Version of Ambience/Repertoire 202x
Stop/Shutdown the current Ambience/Repertoire server.
Unzip the latest version of Ambience/Repertoire 202x.
Mandatory configuration on the new Ambience/Repertoire 202x setup:
Edit the new
etc/application.confcontent base on your previous version of Repertoire/Ambienceetc/application.conf(Do not overwrite the application.conf with your existing one) -
Rename the
bin/run-serverfrom the new Repertoire/Ambience tobin/run-server.bkupand copy over startup scriptbin/run-serverfrom the old Repertoire/Ambience to the new Repertoire/Ambience directory
- Optional Configurations:
JDBC Configuration:
Copy over the database connection pool properties from the old to new Ambience/Repertoire from the
etc/directory. -
Copy over the JDBC database drivers from the old to new Ambience/Repertoire from the
ext/directory.
SSL Configurations:
- Copy over the SSL keystore from the old to new Ambience/Repertoire from the
etc/https/directory or wherever it is stored (refer to theetc/application.conffor the correct location).
Example:
ambience {
systemId: "System"
bindAddress: "0.0.0.0"
bindPort: ${internal-port}
https {
enabled = false
keystore = "https/keystore"
keystore-type = "PKCS12"
keystore-password = ""
client-auth = "none" # none, optional or require
truststore = "https/truststore"
truststore-type = "PKCS12"
truststore-password = ""
Repertoire/Ambience service script
- Linux
Uninstall the service Ambience/Repertoire service first
sudo systemctl disable repertoire
or
sudo systemctl disable ambience
Edit .service file content in /etc/systemd/system/ambience_service or /etc/systemd/system/repetoire_service:
#!/bin/sh -
[Unit]
Description=Elixir Ambience 202x Service
[Service]
User=elixir Do revise the user name as needed.
WorkingDirectory=/opt/ElixirAmbience202x/bin Do revise the path as needed.
ExecStart=/opt/ElixirAmbience202x/bin/run-server Do revise the path as needed.
Restart=on-failure
[Install]
WantedBy=multi-user.target
Use systemd to load new service:
sudo systemctl daemon-reload
Start Repertoire/Ambience service:
sudo systemctl start ambience
or
sudo systemctl start repertoire
Check status for Ambience/Repertoire service:
sudo systemctl status ambience
or
sudo systemctl status repertoire
Enable Ambience/Repertoire service:
sudo systemctl enable ambience
or
sudo systemctl enable repertoire
For more information:
- Windows
Uninstall Ambience/Repertoire window service via CMD/powershell by running from the old version server
elx-ambience-service.exe uninstall
Copy over the window services file from the old server to the new server.
Ambience:
run-ambience-service
elx-ambience-service.wrapper
elx-ambience-service.out
elx-ambience-service.err
Repertoire:
run-repertoire-service
elx-repertoire-service
elx-repertoire-service.wrapper
elx-repertoire-service.out
elx-repertoire-service.err
Install the Ambience/Repertoire service by running the following command via CMD/Power shell
elx-ambience-service.exe install
Or
elx-repertoire-service.exe install
Templates and Data Sources (Repertoire Only)
- Copy over
Repository/directory to the new Repertoire-202x version
Repertoire Users and Groups
- Copy over
data/codexdirectory to the new Repertoire-202x version
ETL module files
- Copy over from
data/in&data/outdirectory to the new Ambience/Repertoire 202x
Start the newly installed Ambience/Repertoire server 202x.
Verify that everything is working as intended.
Please do a rollback to your previous version if you are unable to start the newly installed Ambience/Repertoire server.
Note:
For Ambience 202x installations template,data sources,user and roles are stored in your MongoDB database.
