Ambience 2025.0 Release Notes
Release Notes - Ambience - Version 2025.0
Features and Enhancement
General
  • [Build#70] - Support AWS Assume Roles and SubPath in Binary Store
  • [Build#72] - Uploads to server with allowed extensions
  • [Build#64] - Allow user to navigate to the report output from Ambience Message notification
  • [Build#74] - Async report (Return error code)
  • [Build#77] - Support “Filename” parameter in RML and DocX rendering from web
  • [Build#85] - Arbitrary Request Host Header
  • [Build#78] - Modify Job Priority for Added task(s) in Queue Monitor module
DataSets
  • [DataSets#27] - Support for elx-userId, elx-userName, elx-userRoleNames, elx-userOid in aggregation pipeline substitutions
ETL
  • [ETL-CORE#7] - Allow ETL Parameters to be passed as either string or nested object
  • [ETL-CORE#8] - Substitute I18N step
  • [ETL-CORE#6] - Add ETLJobs indexes for: started, stopped, runId
  • [ETL#149] - Automatic decoding {enc in headers
  • [Build#66] - Repository tagging steps
  • [ETL#147] - Support for larger XLSX files (maximum length for this record type is 100,000,000)
  • [ETL#150] - Workflow new steps: Get Current State, Lookup States
  • [ETL#151] - ETL Dependency Tree Viewer
  • [ETL-CORE#9] - Config Support for JDBC Connection pool
  • [Repository#24] - Enhancement to Git Pull and Git Push steps to accept secret
  • [ETL-AWS#3] - S3 Generate Signed URL step
  • [Report-Portal#14] - New Report Portal Step for migration of report outputs to Report Portal
Scheduler
  • [Scheduler#30] - Allow Scheduler Admin User to modify trigger(s) created by other users
  • [Scheduler#32] - Scheduler WaitForDatabaseRecovery
  • [Scheduler#33] - Enhance filtering timezone drop down
Log Viewers
  • [Log Viewer#12] - Add Roles information in Add User action
  • [Log Viewer#17] - Audit logging of form attachments
  • [Log Viewer#19] - Audit logging for login failures
  • [Log Viewer#13] - Audit logging for Frequency and Job properties
  • [Log Viewer#18] - Audit logging for adding artifact via Upload
Repository
  • [Repository#28] - Migrating customized rml.html pages from Repertoire 8.x to 2024
Report Portal
  • [Report-Portal#12] - Renaming Filename in Render Result Panel
  • [Report-Portal#15] - Collapsible SideBar in Report Portal
  • [Report-Portal#16] - Restrict user’s sharing in the Report Portal by Role
  • [Report-Portal#17] - Report Portal role views
Queue Monitor
  • [Queue-Monitor#14] - Add duration column and Auto Refresh, JobQueue Query ETL Step
User Settings
  • [User-Settings#18] - New User Sessions Panel
Recycle Bin
  • [Recycle Bin#10] - Added more artefact types in Recycle Bin
Licence Deployer
  • [Licence-Deployer#6] - To show warning message before licence expiry
Bug Fixes
General
  • [Build#75] - Fix User will be redirected to “403 Forbidden” page when clicking on the rml template under “Recent” tab
Dashboard
  • [Dashboard#137] - Parse back number selections from linear table to Control
  • [Dashboard#139] - Fix to reset number range in filter
Forms
  • [Form#125] - Fix Repeater Issue
  • [Form#129] - Fix Button overlapped with form dialog frame
ETL
  • [ETL#148] - Fix IMAP reader Base64 Decode
  • [ETL-AWS#2] - Fix for AWS converting our metadata key to lower case
User Settings
  • [User Settings#17] - Add scroll bar for 2FA tab when page height not enough
Users
  • [Users#10] - Fix unfriendly Error message display when access user module
Repository
  • [Repository#26] - Fix error importing files with a Question Mark character into the Repository on Windows
  • [Repository#27] - Fix download Zip folder containing “?” Character returned Error [500] on Windows
Visualisation
  • [Viz#98] - Fix Selections remain unchanged after removal
  • [Viz#99] - Fix Column/Row adjustments may not always function as expected
  • [Viz#81] - Fix Random chart generated
  • [Viz#80] - Fix Columns sorting issue
Import-Export
  • [Import-Export#51] - Uploading a JSON Array File throws an exception
Upload-Download
  • [Upload-Download#28] - Fix Bulk download multiple files returned errors when Mime.Types is included
Queue Monitor
  • [Queue-Monitor#15] - Fix to stop polling when server session timeout
