Release Notes - Ambience - Version 2024.0.8
Bug Fixes
General
- [Kernel#07] - Fix for Negative Number Input Fails in Firefox
Users
- [Users#12] - Changed API Token logic so UUID is controlled from the server
Audit Logs
- [log-viewer#23] - To mask API token in the logs
Messages
- [Messages#26] - Fix Stack trace for inserting duplicated mod-message-send privilege on fresh installed server
RML Engine
- [RML-Engine#35] - Fix default integer parameter is rendered though user updates value
RML
- [RML-Runtime#05] - Fix for issue with RTF Field When Generating Reports with Blank Tables
- [RML-Runtime#10] - Fix cloning JDBC Datasource Error
- [RML-Runtime#06] - Configurable limit to prevent stack overflow in rml pagination
- [RML-Runtime#na] - HTML Callback with Transparent Background Style
Security Bumps
- [Security#na] - Variety security bumps
