Release Notes - Ambience - Version 2024.0.1
Features and Enhancement
General
- [Build#70] - Support AWS Assume Roles and SubPath in Binary Store
ETL
- [ETL#6] - Add ETLJobs indexes for: started, stopped, runId
- [ETL#7] - Allow ETL Parameters to be passed as either string or nested object
- [ETL#8] - Substitute I18N step
- [ETL#147] - Support for larger XLSX files
Bug Fixes
Dashboard
- [Dashboard#137] - Parse back number selections from linear table to Control
- [Dashboard#136] - Fix the Changes made in linear table column reset after making change to Dashboard i18N
ETL
- [ETL#148] - IMAP reader Base64 Decode fix
User Settings
- [User Settings#17] - Add scroll bar for 2FA tab when page height not enough
