Release Notes - Ambience - Version 2023.1
Features and Enhancement
Scheduler
- [Scheduler#27] - Remove Run Once Only trigger after it runs
ETL
- [ETL#133] - CSV writer step
- [ETL#130] - Mongodb Encrypt/Decrypt Step
- [ETL#128] - Update Cached Dataset step
- [ETL#129] - Allow Chain Concat reordering
- [ETL#3] - Update Cached Dataset step
- [Build#49] - Turning ETL logs on in Server log when running from ETL designer
- [Messages#17] - Send Message (Field) ETL step which allows dynamic To, Cc and Bcc via upstream fields
Developer
- [Developer#19] - Delete Confirmation for dropping a collection
Forms
- [Form#76] - New multi-select user chooser
- [Form#75] - Dataset select to use Etag to avoid repeated loading when used inside a repeater
Colour
- [Colour#na] - New Colour module for setting colours
Secret (Early Access)
- [Secret#na] - New Secrets module intended to act as a repository and manager for secrets
Bug Fixes
General
- [Simple SSO#na] - Fix for gitlab authentication
Service Chooser
- [Service Chooser#7] - The unpublished API still show in recent list of non owner users
Forms
- [Form#79] - Repeater with Dots - The repeaters do not retain after user submits Form
ETL
- [ETL#131] - Output job log for Chain Call step when chain not available
- [ETL#132] - Category.src in the Category for all Source Category ETL steps
Dashboards
- [Dashboards#129] - Fix for Decimal formatting in Pivot Table View
