Activity.log can be helpful where it shows information on the time user logged in, the report requested from users and is the report successfully generated.
The below guide is for v7.5.0 and below: (Please scroll further down for v 7.5.1 and above which have better activity log implemented.)
Below explains the messages which can be seen in activity.log:
2009-03-07 09:41:38,262,INFO ,admin , login from 127.0.0.1
Explanation:
User log into the server. For this case ‘admin’ has log into the server.
2009-03-07 11:29:14,756,INFO ,admin , render "/ElixirSamples/Report/Charting/3D Visualization.rml"
Explanation:
It Is added when the user submits the request to the report renderer. This message will also appear if the report is on the queuing list.
For this case ‘admin’ has requested a report ‘/ElixirSamples/Report/Charting/3D Visualization.rml’
2009-03-07 11:29:14,762,INFO ,admin , Task added: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
The report renderer registers the rendering with the task manager(http://localhost:8080/tool/admin/tasks.html). This is the part when the report start to generate.
2009-03-07 11:29:29,763,INFO , , Task Timeout: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml (after 15) seconds
Explanation:
The task has timeout
2009-03-07 11:29:32,836,INFO ,admin , Task finished: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
When the report has rendered, the activity is de-registered from the task manager(http://localhost:8080/tool/admin/tasks.html) which also mean the task has finished and is no longer consuming CPU or memory.
Although the task is finished, it does not indicate whether it was successful or not generated. The task manager just records that a task is being worked on, and then records when the task is no longer being worked on (for whatever reason).
2009-03-07 11:29:32,845,INFO ,admin , render “/ElixirSamples/Report/Charting/3D Visualization.rml”,elapsedTime: 18071 pageCount: 2 byteCount: 262573 mimeType: application/pdf statusCode: 1
Explanation:
It means the data is all processed for reply and any failure from this point onwards is a network failure - nothing to do with data or the report, typically the user has closed the connection.
The statistics are output that describe the render activity and show the summary of the report generated.
Note:
This also means that the report has been written to the output. The output might be buffered and not yet read by the client. Indeed the client may have disconnected without waiting for the reply to complete. We can confirm we have sent the response, but that doesn’t guarantee the user has successfully received.
Example:
If user close the connection while the report is being rendered, or while it is being streamed back to the browser, then user may not get
this report summary because it hasn’t been completely written.
2009-03-07 11:39:32,812,INFO , , Task removed: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
Report has been removed from the task manager(http://localhost:8080/tool/admin/tasks.html).
From v7.2 you can control the task manager property from ERS2.xml:
<ers:mbean name="ERS2:name=ReportMonitorThread"
<ers:property name="Timeout">0</ers:property>
<ers:property name="MonitorInterval">60</ers:property>
<ers:property name="FlushInterval">600</ers:property>
</ers:mbean>
ReportMonitorThread Settings
- Timeout (secs) : How long to wait before cancelling the report
- Monitor Interval (secs) : How often to check if a report has exceeded the timeout time
- Flush Interval (secs) : How long to keep the tasks in the task list once they have completed/timed out.
Why do we need to kill the thread in the task manager ?
If the report goes into an endless loop, eg. a JavaScript says
for (var i=0;i<10;j++)
which will loop forever because j changes, but i is always <10.
Then the report monitor can detect this and kill the task, otherwise it will consume resources and CPU until the server stops.
The below guide is for v7.5.1 and above
2009-04-11 16:34:30,453,INFO ,admin , login from 127.0.0.1
Explanation:
2009-04-11 16:36:32,281,INFO ,admin , render "/ElixirSamples/Report/Charting/3D Visualization.rml"
Explanation:
2009-04-11 16:36:32,390,INFO ,admin , Task added: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
The report renderer registers the rendering with the task manager(http://localhost:8080/tool/admin/tasks.html the Status appear as ‘Started’). This is the part when the report start to generate.
2009-04-11 16:38:40,625,INFO ,admin , Task completed: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
When the report has rendered, the activity is de-registered from the task manager(http://localhost:8080/tool/admin/tasks.html the Status appear as ‘Done’). For any more information you need to look at the final message from the module that processed the task.
2009-04-11 16:24:01,875,INFO ,admin , Task failed: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
When the report has rendered, the activity is de-registered from the task manager(http://localhost:8080/tool/admin/tasks.html the Status will still appear as ‘Started’). This is the part when the report has failed to generate.(Need to refer to server.log for the full error message)
2009-04-11 16:38:40,625,INFO ,admin , render Report 0 “/ElixirSamples/Report/Charting/3D Visualization.rml”,elapsedTime: 18071 pageCount: 2 byteCount: 262573 mimeType: application/pdf statusCode: 1
Explanation:
Finally the statistics are output that describe the render activity. This show the summary of the report generated*.
Note:
This also means that the report has been written to the output. The output might be buffered and not yet read by the client. Indeed the client may have disconnected without waiting for the reply to complete. We can confirm we have sent it, but that doesn’t guarantee the user has successfully received successfully.
Example:
If you close the connection while the report is being rendered, or while it is being streamed back to the browser, then you may not get
*If the Task failed(2009-04-11 16:24:01,875,INFO ,admin , Task failed: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml) this summary message will not display as it is not written to the output.
Below are the Status Code value:
statusCode -1 = NOVALUE
statusCode 0 = STATUS_UNKNOWN
statusCode 1 = STATUS_OK
statusCode 2 = STATUS_NO_DETAILS
statusCode 3 = STATUS_NO_DATASOURCE
statusCode 4 = STATUS_LOGGED_EXCEPTION
statusCode 5 = STATUS_CANCELLED
statusCode 6 = STATUS_TIMEOUT
statusCode 7 = STATUS_NO_REPORT
statusCode 8 = STATUS_UNABLE_TO_COMPLETE
statusCode 9 = STATUS_NO_JOB
2009-04-11 16:48:40,625,INFO , , Task removed: Report 0 /ElixirSamples/Report/Charting/3D Visualization.rml
Explanation:
</ers:mbean>
