This allows a separate log file to be created that only tracks a composite datasources’ processors activities.
Add in the following codes into the \RepertoireServer\config\log-config.xml (For Server Version 7.x)* -
<appender name="MyCompositeLogger" class="org.apache.log4j.RollingFileAppender">
<param name="File" value="../log/MyCompositeLogger.log"/>
<param name="Append" value="false"/>
<param name="Encoding" value="UTF-8"/>
<param name="MaxBackupIndex" value="5"/>
<param name="MaxFileSize" value="500KB"/>
<layout class="org.apache.log4j.PatternLayout">
<param name="ConversionPattern"
value="%d{ISO8601},%t,%-5p, %c{2} - %m%n"/>
</layout>
</appender>
Note: The above is added to the first instance of the appender method in log-config.xml.
<category name="MyCompositeLogger">
<priority value="debug" />
<appender-ref ref="MyCompositeLogger" />
</category>
Note: The above is added to the first instance of the category method in log-config.xml.
Adding Logging Statement within composite
Under the “Script” Tab of a composite datasource …
importClass(Packages.org.apache.log4j.Logger);
var logger = new Logger.getLogger("MyCompositeLogger");
logger.info("Start");
