Instructions for modifying the partition-limit
setting in the RML runtime configuration to address tree depth limitations in report generation.
Steps to Adjust Partition-Limit
Add the following configuration in the application.conf
file, located in the /etc
folder of Ambience 202x directory:
elixir.rml {
# Depth of the tree that can be split across pages before throwing an exception.
# Adjust this value based on the size of your largest report.
partition-limit = 100
Please restart the Ambience server to apply the changes.
Note:
- The default
partition-limit
value is10
, sufficient for most cases. - Increase the value (e.g.,
20
,50
, or higher) based on report size and complexity.
