[Troubleshooting] Unexpected Socket Closure in Oracle JDBC Communication
This entry explains the causes and potential resolutions for the error “java.sql.SQLRecoverableException: No more data to read from socket”. The error occurs when the database connection is unexpectedly closed by the server while data is still being read, or when communication between the client and the database server fails.
Step 1: Identify the Error Context
The error typically arises during report generation or query execution where the client is actively reading data from the database. The connection is terminated prematurely, resulting in the socket read failure.
Step 2: Learn Common Causes
Several factors can lead to this error:
1. Network Issues
  • Interruptions in the connection between client and server.
  • Server unable to maintain proper communication with the database.
2. Client Socket Timeout
  • No data sent from the client for a specified duration.
  • Server closes the connection, causing the error when communication resumes.
3. JDBC Driver and Database Version Incompatibility
  • Mismatched Oracle JDBC driver version and Oracle Database version.
  • Incompatibility may trigger unexpected behavior or communication errors.
Step 3: Apply Recommended Actions
To mitigate or resolve the issue:
  • Verify network stability between client and database server.
  • Check and adjust socket timeout settings to ensure they align with workload requirements.
  • Confirm that the Oracle JDBC driver version is compatible with the Oracle Database version in use.
  • Upgrade or align driver and database versions if incompatibility is detected.
What This Clarification Achieves
  • Provides insight into why the error occurs.
  • Outlines the most common root causes.
  • Suggests practical steps to stabilize database communication and prevent recurrence.
