This is an example on how to call Ambience/Repertoire 202x API to output a RML template using curl.
Rendering RML Template w/ Parameters
API Structure:
[protocol]:[host]:[port]/rml-engine/render?elx-token=[token-value]
Create API Token
Add an API token and assign a user account to this API token. The API token string will be appended to the API call in a later step.
Create Role
Add a role and assign a user that has the following access privileges, mod-ds-engine & mod-rml-engine
Sample Report Template
For this example we will use a sample report template with a parameter. The path of this report is:
For example, “/QA_Samples/RML/Parameters/Password_Parameter.rml”Creating a HTTP call
Using the HTTP endpoint, construct the HTTP call to the rml rendering engine by appending ‘?elx.token=’ & the API token.
For example,
“http://localhost:1740/rml-engine/api/v1/render?elx.token=6175c322-e5bf-425c-b10d-78d886092e52”
Construct a header in JSON format.
For example,
-H “Content-Type: application/json” -d “{"rml":
"/QA_Samples/RML/Parameters/Password_Parameter.rml","Password":
"testparameter","renderDetails": { "RenderAsImage": "Yes", "AllowScreenReaders": "No" }}” -o result.pdfTest the API call using curl
For example,
curl -v -X POST
http://localhost:8081/rml-engine/render?elx.token=6175c322-e5bf-425c-b10d-78d8
86092e52 -H “Content-Type: application/json” -d "{"rml":
"AllowScreenReaders": "No" }}" -o result.pdf
Notes:
- Another way would be to write the report template, its rendering options and parameters to a JSON file and specify the path of the JSON file.
- For more details, do take a look at this documentation:
Rendering a report template via REST API.pdf (287.6 KB)
Rendering RML Template using Tabular Datasource
API Structure:
Create API Token
Create Role
Upload the Tabular Datasource up on the Repository module.
(i.e. FruitSales)In your local system, edit the RML template using an editor of your choice.
(i.e. Notepad++)Go to ‘rml:datasource’ tag & edit the ‘datasource-name’ path to the datasource path over in Ambience 2021.
For example,
Save the RML template & upload it up to Ambience 2021 Repository Module.
For example,
“http://localhost:1740/rml-engine/render?elx.token=6175c322-e5bf-425c-b10d-78d886092e52”
Test the API call using CURL
For example,
curl -v -X POST http://localhost:1740/rml-engine/render?elx.token=6175c322-e5bf-425c-b10d-78d886092e52 -d ‘{“rml”:“[path-to-report]”}’ -o result.pdf
Reference: Report and Datasource Engine Modules · Repository
