Introduction
Repertoire Server 8 has greatly improved the configuration of the system environment such as repository filesystem and user access security. A web interface is provided for administration, repository browsing, triggering of reports, and accessing to reports, data sources and dashboards.
The JMX HTTP console is no longer required as system monitoring is supported via standard Java JMX console, available as part of Java Development Kit.
Repertoire Server 8 provides a new REST APIs to access the entire range of server services. The Java ERSClient API for rendering reports and data sources is retained for backward compatibility.
Perspective is now part of Repertoire 8 Server component. The Perspective Servlet web archive file or a separate J2EE server is no longer required. You are advised to retest all dashboards designed in Repertoire 6 with Repertoire 8 Designer and Server. Minor modifications may be needed to support new features implemented
such as a fixed-sized card dimension and the use of borders with margin and padding for aesthetic and precision layout control.
Installation
Do NOT attempt to install version 8.x over on the same location as an existing version 6.x installation as this would cause ERS 8.x not to start up correctly.
The minumum Java Run Time requirement for version 8.x is Java 6 and above whereas the minimum Java Run Time requirement for version 6.x is 1.4.
Configuration
Do NOT copy all configuration files in <ERS6_installation>/config over to <ERS8_installation>/config as this would cause ERS 8.x not to start up correctly.
Core Engine
The default port used for ERS 8.x is 8080. Port 8089 used in version 6.x is not longer required.
External Jars
Please copy all existing jars in ERS6.x ext folder to the new ERS8.x ext folder.
Repository
<server_installation>/config/repository.xml ( in version 6.x ) is no longer applicable in 8.x server. Hence you need to add all the filesystems used in Version 6.x in Version 8x through the Administration web interface. All the repository settings would be stored in the database in Version 8.x.
Users/Roles
<server_installation>/config/user.properties and <server_installation>/config/role.properties ( in version 6.x ) is no longer applicable in 8.x server. Hence you need to add all the users/roles configuration used in Version 6.x in Version 8.x through the Administration web interface. All the repository settings would be stored in the database in Version 8.x.
User “Anonymous” ( in version 6.x ) needs to be explicitly created in version 8.x , if required.
API
In version 6.x , the following jar files are provided :
- Glint.jar
- jdom.jar
- log4j.jar
- mx4j-rimpl.jar
- mx4j-rjmx.jar
- RepertoireClient.jar
- servlet-api.jar
In version 8.x , the following jar files are provided :
- Glint.jar
- log4j.jar
For existing Java application making use of ERSClient to access server-side resources, please remove all 6.x jar files as mentioned above and make available the new 8.x jars in your Java Enviroment.
Known Difference between version 6.x and version 8.x
- In version 8.x,
- com.elixirtech.ers2.client.ERSClient.getFile()
- com.elixirtech.ers2.client.ERSClient.getReport()
does not include the filesystem name when the value is returned.
e.g
- In version 6.x the getFile() or getReport() method will return “/ElixirSamples/Report/Charting/3D Visualization.rml”
- In version 8.x the getFile() or getReport() method will return “/Report/Charting/3D Visualization.rml”
As a workaround, the filesystem name needs to be appended programmatically.
e.g.
_String test = "/"+"MyFileSystem"_
_if (!test.startWith(reportpath)) // Test if the reportpath return contain the filesystem name_
_{_
_reportpath = test+ reportpath // If not, append the filesystem name to the report path_
_}_
- In version 8.x, ReplyTarget is implicit therefore “me” is not needed to set the target.
e.g.
In version 6.x - client.renderReport(rptName, “application/pdf”,fos,props, “me”);
In version 8.x - client.renderReport(rptName, “application/pdf”,fos, prop);
Deprecated Methods
- com.elixirtech.ers2.client.ERSClient.renderReport(java.lang.String report, java.lang.String mimeType, java.io.OutputStream os, java.util.Properties properties, java.lang.String target)
- com.elixirtech.ers2.client.ERSClient.setConnectionMode(short mode)
- com.elixirtech.ers2.client.ERSClient.setAutoEscape(boolean b)
- com.elixirtech.ers2.client.ERSClient.isAutoEscape()
- com.elixirtech.ers2.client.ERSClient.isConnected()
MigrationGuide-6.x-To-8.x-v1.0.doc.zip (1.4 MB)
MigrationRepertoire6to8-OverviewandChecklist.pdf (153.4 KB)
