Integrating Repertoire Server with Active Directory
The ActiveDirectory_Secondary_Authentication.pdf (708.7 KB) highlights how the Repertoire Server is integrated with an active directory using the sAMAccountName as the log in attribute. In addtion, for environments where the Repertoire Server and active directory reside on different platforms a search and bind function is required to log onto the active directory before carrying out the server authentication.
The following are covered -
- Configuring the Repertoire Server
- Input of active directory attributes
- Search and bind
- Frequently Asked Questions
Note: It is recommended to upgrade to version 7.3.x and above if the abovementioned scenario fits your system requirements.
