Atomic Integer
This recipe is an example of how to design a simple ETL Chainset for the step, “Atomic Integer” using the ETL Designer module on Ambience 2021.
Background information on Atomic Integer:
  • This step reads and increments an integer value in MongoDB in a thread-safe way so that multiple concurrent calls will each receive a different incrementing value.
  • More information can be found in the ETL Dictionary.
Prerequisites:
  • A database:collection which will hold the counters.
Notes:
  • A collection can have many counters but each counter needs to be identified by a unique _id string identifier
ETL Atomic Integer:
This example uses a database:collection that consists of the following data:
{"_id": "InvoiceNo", "Type": "InvoiceNo", "Value": 45 }
{"_id": "QuotationNo", "Type":"QuotationNo","Value": 100}
  1. After importing the data, head over to the ETL module.
    More information on how to Import data can be found here: Imports
  2. Create a new ETL Chainset.
    For example,
  3. Add a new Blank Chain.
    For example,
  4. Add the step, “MongoDB Atomic Integer” in the new chain & fill in the fields:
    For example,
    *expand the icon on the top right corner for more details on this step.
  5. For visualization purposes, do add in the following 2 steps, “MongoDB Definition” & “MongoDB Reader”
    For example,
  6. Run Steps.
Output:
// Initial Data
// After running the steps
[Value for InvoiceNo is incremented by 1]
// To increment “QuotationNo”, do add in & configure another “MongoDB Atomic Integer” step.
